Well, I didn't have enough pain in my life so I adopted an old Austroflamm Integra. Adopted isn't really the right word because I paid $500 for it. It wouldn't stay running but the auger light came on motors spun for a minute before it would shut down. The stove was really dirty. It looked like it hadn't had a good cleaning in forever. The PO said it was running "rich" but didn't know anything about the stove or how to fix it. I noticed the door latch was pretty loose and didn't close very tightly. I don't think it would've passed a "wad of dollar bills" test. I took a chance on it hoping I could get it going. The cast plates are in good shape so I figured I could part it out if worst came to worst.
Thank goodness the guy had a buddy there when I bought it and they helped me load it in the truck. That stove is heavy. The first thing I did was start to clean it. I got the cast plates out of the firebox and there was a ton of ash behind them, I vac's everything out and found the cleanout plate in the back of the stove. I got three of the screws out but the fourth wouldn't budge. I sprayed it with PB Blaster and gave up on the screw to let it soak. I adjusted the door latch and figured I'd try to start the stove in the driveway. It started and ran for about fifteen minutes and then shutdown. No biggie as it was time to go to bed anyhow. The stove was a lot quieter than my other stove. Must be all the cast iron. I did some checking and I think the fan limit switch might be bad. A couple days later I used an impact driver to finally break the screw loose. I don't think the PO ever cleaned out the back chamber because it was almost full of ash. Tonight I'd like to get it going in the driveway again and check the fan limit switch with a meter once it's going. I have to get some gaskets and such and I want to make sure this stove will run reliably before I consider pulling my other insert out.
Anyhow, I've attached some pictures of the Integra. Looks like it was ridden hard and put up wet. I'll update the photos once I chisel off the soot on the glass and repaint the side panels and the top of the stove.
![New-to-me old school Austroflamm Integra New-to-me old school Austroflamm Integra](https://www.hearth.com/talk/data/attachments/115/115408-f97d634e422ce740faae1f5592872d57.jpg)
![New-to-me old school Austroflamm Integra New-to-me old school Austroflamm Integra](https://www.hearth.com/talk/data/attachments/115/115406-16e074bad7906200f69e7e96d7a515df.jpg)
![New-to-me old school Austroflamm Integra New-to-me old school Austroflamm Integra](https://www.hearth.com/talk/data/attachments/115/115407-9a4f5795c4631cb9a9e866c3015db0cf.jpg)
