I've got the wood bug...pretty bad. Got a wood stove about a year ago and I'm always looks for 'volunteers' (standing dead trees) that I can get. Any time a neighbor needs a tree taken down I jump at the chance - they think I'm crazy. I've got a bunch of mauls and a few home ownery chainsaws (Rancher 455, 2 x Stihl MS 250s, and an Echo top handle saw). I'd been watching Craigslist like a hawk for a while hoping to score a good deal on a pro grade saw. A 1993 Husqvarna 242xp showed up and I pounced on it.
I haven't done much cutting with it, but the little I've done there is definitely a serious lack of oil making its way to the chain. There's a decent amount of oil mucking up everything inside the clutch cover - it just doesn't get to the chain. I've tried 2 different chains, cleaned the bar groove and oiler hole and flipped the bar over.
It appears the oil is going behind the thin sheet metal plate and oozing out underneath it in lots of different directions - and hardly anything makes it to the chain. The bar groove and oil hole get wood gunk in them after a couple of cuts - I wouldn't say they're clogged, just gunked up a bit than what I'd consider normal.
The bar and chain get very hot after a few minutes of cutting and the teeth on the chain get the nasty brown scorched color - its too hot to touch. I can't feel any oil on the chain after it cools down.
When I set it down right after a few test cuts a little pool of oil will form on the ground, and sometimes chunks of oil soaked sawdust falls out. When I take it apart there is a lot of oil all over the clutch cover and the body of the saw.
Is there anything that I can do to make the oil actually go through the groove and make it into the bar and chain and NOT go behind the thin piece of sheet metal? I something else happening? Am I missing something?
Any help would be greatly appreciated. I'm dying to go cut up anything I can find with my new old saw!
![New-to-me 242xp doesn't get oil to the chain New-to-me 242xp doesn't get oil to the chain](https://www.hearth.com/talk/data/attachments/179/179026-8c98f0972ad7bbd6e5eb4383173adaa9.jpg)
![New-to-me 242xp doesn't get oil to the chain New-to-me 242xp doesn't get oil to the chain](https://www.hearth.com/talk/data/attachments/179/179027-d3d71d243b9e2f618363b990c62e65f3.jpg)
