Hello
I have a Buderus G115WS/4 with Carlin Burner and Superstore Indirect for DHW. There are 3 Zones using 2 Taco SR-501 relays, Sweat Checks in the supply lines and Taco 007 Circulators.
Everyone says that the Indoor Sensor helps get the room up to the target temperature faster because the feedback room temp is used for the base of the heating demand curve in the Tekmar 260.
Here is the question for this split entry.
Zone 1 goes to all the bedrooms at one end with the thermostat in the Master Bedroom. Heat is turned up more at night.
Zone 2 goes to the living room and kitchen at the other end. Heat is turned up more in the day.
So where does the indoor sensor go for best results??
See wiring diagram below:
