Would i be right in saying when the fans not running there is no draft.
There is no forced draft; there will be some draft from chimney action pulling air through the draft fan damper, but not enough to maintain a burn.
The draft fan should run continuously until the temp reaches 180-190, depending on your temp control setting. Turn it all the way up, and the fan will shut down at about 190, and come back on at about 180, and then cycle.
Lots of different starting techniques. What works best for me is laying the kindling, then two newspaper knots in top down method. As soon as I light the paper, I leave the firebox door and gasification chamber doors slightly ajar, and start the fan. In just a couple of minutes the kindling is blazing well, shut off fan, add small splits to about 1/3 full, still leave doors ajar, restart fan. In another couple of minutes this will be blazing well. I then shut both doors, and flame shoots through the nozzle, secondary burn starts almost right away, and then gasification. Let this burn awhile to get a fair bed of coals started, then load firebox for main burn.
I almost always leave the air adjustment lever in the middle; works very well for dry wood. Not so dry wood might need a little more primary air, slide lever to the right a bit. I don't fuss with this lever much at all - leave it in the middle and forget it.
If you don't get or can't maintain a strong burn most of the time, check the damper setting on the draft fan. There is a fixed adjustment and a variable adjustment. Adjust these (damper more or less open when fan is on) to maintain stack temp within desired range during main burn. For me, probe temp 400-600 is normal, with 600 during early part of high burn, and 400-450 during most of burn.
