Hi All,
After many years of reliable service my 1994 Austroflamm Integra insert pellet stove is having a problem. Looking back, its only repair was an auger motor replacement a few years ago, so I have nothing but praise for this trusty old friend. Anyway, the problem is that theconvection combustion motor won't shut off unless the stove is unplugged. Everything I have read so far indicates that a low limit switch is responsible, so I did the following.
I removed the switch, heated it up slowly until I heard a click and then checked across both terminals for
continuity. There was continuity along with zero resistance. Next, after waiting a while for the switch to cool-down and hearing a click, I checked for, and confirmed a disconnect. The next day I reinstalled the switch back into the cold and unplugged stove. I then plugged in the stove but did not turn it on, however the fan ran anyway. Then while the fan was running I disconnected both limit switch terminal wires but the fan still ran. So now I am thinking there may be another reason for the problem.
Your advice and comments would be appreciated.
Thanks,
Frosty
Thanks,
Frosty
