Hello all,
My wife and I moved into a house built in the early 1900's and we moved in during May of 2017. The house is only 1600 square feet and has two additions that were built on after the original construction. The previous owner had a buck stove insert placed in the mid 90's and used it as a secondary heat source (the house also has an electric heat pump/central air.) The previous owner always cleaned the chimney himself and said that he has never had issues with the buck stove.
Last winter we burned about two cords of wood with no problems at all,and today I had a guy with a local chimney/masonry place come and inspect/clean the stove and chimney. He stated that the flue liner does not go all the way to the chimney cap and he indicated this is a problem and is not up to code therefore he could not recommend burning wood this winter. The chimney is approximately 25' in length (guesstimate), he is not sure how far the liner is from the top but states he could not feel it from the top of the chimney.
He also stated before he left that the liner is only 6" when it should be 8" and that if the original fire place that was here had any of the "heat shield" cut then it isn't safe for any type of wood burning insert. I am a complete novice when it comes to anything wood burning related. I used this site last year to teach me how to get an efficient fire going and after 7-10 fires I was able to have a really good burn with excellent heat last winter. The masonry around the insert last year was never warm to the touch, and I had little to no smoke at all out the top of the chimney. He said that the catalytic combustor looked newer and was very clean.
Is this set up safe to use this winter and to continue to use? If it is not, could someone explain to me a little more as to why it isn't safe. I do understand that with a 6" liner in an 8" chimney leaves space around for creosote/ash/etc. to fall in between so that concerns me a little. I have three pics showing the stove, the chimney coming out of the roof, and also a pic from the attic showing some of the chimney.
Any information or input would be greatly appreciated. If I did not do a very good job explaining please let me know and I will try to add more specifics.
Thanks!
![New member with buck insert and liner question New member with buck insert and liner question](https://www.hearth.com/talk/data/attachments/230/230486-4de539b295aa0f88568a5b0527967b28.jpg)
Thanks!
![New member with buck insert and liner question New member with buck insert and liner question](https://www.hearth.com/talk/data/attachments/230/230482-e40c964ed6f0fba6df0bf95e150993c9.jpg)
![New member with buck insert and liner question New member with buck insert and liner question](https://www.hearth.com/talk/data/attachments/230/230483-5774dd5ed3da9d99f7fd155e005bda77.jpg)
