![New Member Setting Up Masonry Chimney for BK New Member Setting Up Masonry Chimney for BK](https://www.hearth.com/talk/data/attachments/245/245912-c5d8795670dba03a4d33f4ce029e7efa.jpg)
![New Member Setting Up Masonry Chimney for BK New Member Setting Up Masonry Chimney for BK](https://www.hearth.com/talk/data/attachments/245/245913-ad09ae9a042da9cc97450435873f49e3.jpg)
Hello, everybody! I have been reading this forum for awhile to learn more about heating with wood stoves. I am currently setting up a chimney for a Blaze King, and would like to check to make sure I am not making any mistakes so I do it right the first time. Sorry this is so long.
Background
My house will need supplemental and back-up heating for power failures, as we get ice storms here that have been known to cause outages lasting days or a week. This means a wood stove at my house might only be operated for a few weeks or a month in late December and into January, our coldest month.
I am looking at a Blaze King Boxer 24 or Chinook 30.2. I am attracted to Blaze King because of the long, low burn times. It will be my first and only (I hope) wood stove. I understand from reading this site and the stove manuals that proper draft and dry wood are critical for EPA stoves like these. Because I plan to age in place, I care a lot about energy efficiency. Because my health is already declining, I don’t want to have to load a stove any more often than necessary. On page 16 of the stove manual https://www.blazeking.com/wp-content/uploads/2018/11/OM-BX24-E.pdf is a drawing of an installation in a masonry chimney. My chimney flue has no jog in it...it just goes straight up. And it doesn’t have a big open space below the tee either.
Since my recent retirement, I have been working on renovating a 1903 two and a half story house in St. Louis, MO. Urban houses like mine are tall and skinny, and they are full masonry, with the front of the house three stories tall and the back of the house two stories tall. The floor plan is shotgun style. The first floor is about 720 sf, with three rooms and a long hallway on the west with two staircases, one to the second floor and the other to the third floor. Houses like mine were designed to act like giant chimneys, back when fuel and labor were cheap.
Both my roofs are flat, with rigid insulation and TPO roofing. I will be adding as much insulation as I can, both under the roofs and in walls that can be furred out. I will be adding wooden storm windows to windows that have already been weatherstripped with interlocking tee-shaped and vee-shaped weatherstripping. The first through third floors will have exhaust fans in the bathrooms and over the cooktop, and the clothes dryer on the second floor will be ventilated to the exterior. Although the first through third floors will be pretty air tight other than exhaust fans, the basement will be unconditioned and leaky. It will contain no combustion appliances, as the heating/cooling and DHW will be electric. There are floor grates from the basement to the first floor, left over from the days when there was a big coal furnace in the basement that is now gone. So I am looking to the basement to provide fresh air to the wood stove.
Chimney/Flue
The wood stove will be in the back room on the first floor, which is only 12.5’ x 12.5’ x 10’ high and is the northernmost room on the first floor, right next to the staircase to the third floor. The chimney is on the exterior wall, which is typical of houses like mine. The chimney has three flues, and my friend Karl and I opened up the northernmost flue for the stove chimney. This means the stove chimney will be 10’ away from the back of the third floor. The other two flues will not be in use.
To make sure the chimney is high enough, I have asked my mason friend Lenny to rebuild the chimney to extend just the stove flue, restoring the original height of 6’ above the second floor roof. Years ago, Karl and I took down the chimney to parapet height because it was in danger of falling down. So Lenny will rebuild an unlined 18” x 18” (exterior) chimney above the parapet. The interior of the chimney will be about 10” x 10”.
Karl and I plan to use a 6” smooth wall flexible stainless steel liner with a tee at the bottom and a stainless steel anchor plate on top. Because the chimney will be 2’ shorter than the third floor roof height, we will attach a 6” x 4’ Class A pipe to the anchor plate, topped with a rain cap with a spark arrester. This will being the chimney height up to 2’ above the highest part of the house. From the top of the Class A pipe to the thimble on the first floor will be about 26’.
Because the flue is very uneven on the interior, we are concerned that liner insulation might tear. So, even though the flue measures 10” x 10”, we plan to pull and center the 6” liner, and then fill the flue around the liner with vermiculite slurry. I plan to pack the area around the tee at the bottom of the liner with Roxul insulation.
Does all this seem OK so far?
Air Intake
The Boxer 24 has no fresh air intake kit. Because my basement is leaky and unconditioned, should I cut a grate into the floor under the stove to supply fresh air? If Yes, where should I locate it? The manual doesn’t describe where the stove pulls in air...
Clean-out
To clean the chimney, I wonder if I can install a cast iron clean-out door somewhere low in the flue...I’m not sure where. We already opened the chimney breast to a level about 3+’ off the floor, which would be at the same height as the top of the stove, and cleaned out the flue. I was thinking we could install a clean-out door there, so I can reach in and up, put a little box under the tee, pull the bottom of the tee off, and let the creosote fall into the box. I hope someone can advise if we need to place the clean-out somewhere else or structure it in a different way.
Wall Surface Behind Stove
I have salvaged a lot of slate shingles, and was planning to install concrete board over the chimney breast (which is brick with 1” of plaster on it) and then shingle the concrete board with the slate, using copper nails. Does this sound OK or do I need to build a structure that provides an air gap behind it?
Thank you!
