Hello from Julian, California! I recently moved up into the mountains of Julian and "inherited" a Vermont Castings WinterWarm catalytic stove insert.
I have read through the forums and suffice to say, I'm stuck with it for this winter. On the upside, this house was a basically a summer home and the stove is in really great shape. I had to pull the door, fix the bent hinges, re-rope the door seals, spend a lot of time "adjusting/grinding the door latch, and now I can make it "limp along" with a defective damper. The damper retainer is, well, not retaining. I can only open the damper 1/2" at the full open position of the lever. Can anyone tell me if removing the back damper plate is just a remove-3-bolts affair? Is it really that easy or am I missing something?Whether the damper lever fell off the retainer or the retainer is broken , I believe this is what I need to repair. I have new flue plate gasket rope and cement on (back) order because I am guessing that this is a onetime use gasket(s) on this stove. ANY help is greatly appreciated! Thanks!
Sign me: Overworked
Sign me: Overworked
![[Hearth.com] New member introduction [Hearth.com] New member introduction](https://www.hearth.com/talk/data/attachments/320/320434-39093ea01a0b0d4374fa2a32a015b9f7.jpg?hash=f_WQCyiPnY)
