Hi all,
Long time reader, first time poster. I (think) know the drill.![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
I am looking to install a second stove in my some-what leaky, 225 y/o, 1600 sq-ft Vermont home. The house was largely remodeled in the early 1980s (new insulation, storm windows, some air sealing, etc). This fireplace sits in a large living room and has two bedroom doors off it. At the other end of the house (and separated by a narrow hallway with two small doorways) is another, identical hearth that is in the kitchen/dining room. The kitchen has an older 2-door Jotul F400 that has been a good stove and serves that end of the house well. It is simple, produces plenty of heat and we're fine with it.
My issue in wanting a second stove is that the layout of the house is not conducive to airflow and its not uncommon for the kitchen to be 80 degrees and the other end of the house to be 60 degrees. I was imagining installing something with long burn times that would be able to keep the chill off that end of the house without needing to feed a second stove as often as I feed the Jotul F400. Something like a BK Ashford 30 would be perfect but I learned that that particular stove is does not have a fireplace/hearth mount clearance tested like my F400 does and as such the mantel trim would need to be 37" above the top of the stove, which is not happening.
I'm looking for the following inputs from anyone with more experience who might be able to help shorten the path to figuring out this install.
- Would a mantel heat shield be appropriate for this type of situation and are there any code numbers out there for how much they can reduce clearances for mantel trim/mantels? Might that be a way I could make an Ashford work?
- My research hasn't turn up many 'hearth mount' style catalytic stoves. Any you would suggest?
- There are a numerous non-catalytic stoves (such as my F400) that can be safely installed in this space. If I had to go that way, I'd lean towards something like the Hearthstone Homestead.
She who must be obeyed is not interested in an insert. Luckily, I'm not really either.
See photo below for install space. Dimensions:
- 60" across the opening
- 21" from the back of the fireplace to the opening
- 55" total from the back of the fireplace to the front of the hearth
- 48.5" from the floor level to the bottom of the first trim piece
- 62.75" from the floor level to the bottom of the mantel
![New install hearth mount plans for input New install hearth mount plans for input](https://www.hearth.com/talk/data/attachments/242/242064-26b6b4f96b6155eec0be60accaf97bd1.jpg)
