Hi All,
As the title implies we just moved to a new house and with that came a Lopi Liberty woodstove and a CB E-classic 2400. I'll start another thread on the latter. Prior to this we heated with a BK princess for 6 seasons and then a Woodstock Fireview 205 for a partial season up to December, abeit in a slightly smaller house that was insulated very well. I've attached a picture of the stove setup for review.
So far I've read through the manual a few times and poked around on the forums here but can't seem to find the answers I'm looking for so figured I'd ask the pros.
1. Twice now, on colder nights, I've reloaded the stove very full and followed the manual for rough times to get the fire nice and hot before turning it down. I was measuring stovepipe temps at either 550 or 625. The first was using the stovepipe gauge and the 2nd using an IR sensor. Not sure which is really correct. Well, after pulling the air adjustment out for overnight burn I've noticed that the stack temp and stove temp continue to rise. I could hear the air being sucked into the stove and it was almost as if the air control wasn't working properly. Finally I "shut" the air control but this did nothing really as the stove continued to get hotter. I figured it might just be a delayed effect but it continued to rise. At this point I pulled a handful or Roxul insulation from a spare bag and stuffed some pieced into the front air intake, or what I thought to be the front air intake. After about 30 minutes the temps stopped rising and slowly started to drop. I waited until things stabilized and then went to bed. In the morning, almost no coals left and stove was about 150F. I'm not sure if I actually did "block" the air, or if this was going to happen anyway and was just coincidence. Since then I've just been building smaller fires and reloading them more often. It seems the air control actually works when I run the stove like this.
2. Maybe this has something to do with problem 1, maybe not, but I can't seem to get the rated 12 hours out of this stove no matter what I try. The previous owners left about 1 cord of what appears to be dry hardwood, definitely some oak in there too. The wood feels dry, lights easily and doesn't steam much if at all. Unfortunately this is all based on opinion since my moisture meter is packed away into a box somewhere. Several times now I've reloaded the stove around 11PM and the following morning at 7 there's just a few coals left. Pretty much the same story as above. Maybe the real issue here is the BK we heated with previous. On normal days (highs ~30, lows ~ 10) it would go 12 hours easily, 16 with the right wood/splits. That was using 2 year stacked/covered hardwood.
Any thoughts on the above? Any and all feedback is greatly appreciated!
![New house, new (to me) Lopi Liberty New house, new (to me) Lopi Liberty](https://www.hearth.com/talk/data/attachments/241/241091-1c3cc39621f40a238c42a123ec752972.jpg)
