Hey all! Been lurking on these forums for a while as I've been researching upgrades to my heating and HVAC. Currently have an LP primary furnace (Trane XR95), and previously had a Hot Blast furnace installed as an add-on.
House stats: I have a ~1700 square foot single-story ranch (built circa 1959) in New York's Capital Region (Glenville, if anyone knows it), and all the furnaces are located in the basement (~1400 square feet).
After a lot of reading and research, and a nicely-timed 26% federal tax credit, I bought a Heat Commander and traded the Hot Blast to an HVAC guy for the cost of installing the new furnace. Pretty good deal, I think. I have it wired up in the interlock configuration depicted in the manual for a parallel add-on.
I'm having a couple of issues with it, and I think I know the solutions, but wanted to make sure I've got my understanding correct. I'm consulting with the HVAC guy, but figured there's a lot of expertise here, so more opinions is more gooder.
1) I've read that, ideally, you want backdraft dampers between the furnaces and their entry point into the main trunk of the ducting. We didn't do that on the install so I'm going to have to refit it, but I wanted to double-check what exact kind of damper I'd be looking for. Seems like these round gravity dampers are the most common:
www.greenheck.com
But I was wondering if a rectangular type configuration would also be workable? I have rectangular ducts, so I think it'd be easier to fit:
www.greenheck.com
It's aimed at roof-mounted exhaust fans so my assumption is "no," but it also seems like it might work?
2) As you might imagine, because there are no backdraft dampers, the systems push air through each other - when either blower is running, it pushes air backwards through the other furnace. This is probably not great? In particular, when the LP blower is running, it stops the wood furnace from building meaningful heat in the plenum, and puts it into the basement.
The obvious answer here is "backdraft dampers for the furnaces," but I've been reading about folks who have backdraft dampers in their return air ducts as well. Can anyone speak to that? Necessary? What exactly are they doing?
3) Currently, I don't have it ducted to the cold air return either, my assumption being that my basement air volume is more than sufficient. However, seems like I'm having trouble pushing heat from the furnace to the far corners of the house, so it's pretty clear that the air volume in the basement is insufficient. I'm also assuming that a return duct will do a substantially better job of maintaining the correct static pressure in the system. Any particular tips I should know about running a new cold air return? Size it to be at least as large as the hot air outlet?
4) I think, but I'm not 100% sure, that I might not be getting enough combustion air. I didn't attach the additional combustion air supply adapter, once again assuming the basement air supply was more than enough, but I'm wondering if the combination of no air return and no combustion air is just leaving the thing starved for air. That would track with performance, because when the fire got low last night, I wound up getting acrid/smokey air in the house, like a fire that was being strangled.
Has anyone attached the additional combustion air? Any advice on that?
Thanks in advance!
Dampers
Greenheck Fan is the worldwide leader in manufacturing and distributing air movement, air conditioning and air control equipment.
![www.greenheck.com](/talk/proxy.php?image=https%3A%2F%2Fwww.greenheck.com%2FContent%2FGreenheckStyles%2Fimgs%2Ffavicon-16.png&hash=6301401bc3b443244e781165c37a3905&return_error=1)
Dampers
Thanks in advance!
