Have a beautiful new Clydesdale all set up and running, going through break in fires right now. What is the best thermometer placement and what type should I use. If your recommendation is a probe type, where do you place that and how? Thanks all.
That sounds like a good set up. I must say the stove is incredibly easy to use. I'm not sure how necessary a thermometer is.We used to have a magnetic mount temp gauge next to the draft bolt on top. Just left the warming grill off. Now we have a digital gauge with the sensor held down by part of the draft bolt. Allows us to have the warming grill back on.
We have a large well insulated house with a fairly unique open concept floor plan. I'm guessing this can cut our heating bill at least in half if we use it all the time. I was running a Woodstock Keystone before and I brought about 6 cords of wood with me when we moved to the new house. This stove I think will run better on thicker pieces of wood than the Keystone liked so I suspect we'll be reloading a bit more often than necessary until we get to wood cut and split for the Clydesdale. Gotta burn dry wood, that is key! Most of mine is probably at least 3 years dry, perhaps some pine and red maple might be two but you are so correct. DRY wood, thanks for your input.As you can see from the photo, I have an Omega, 0 to 700 degrees F, thermometer, leaning up against the flue collar - more or less. No mater where you place any temperature measuring device, all measurements are going to be relative. I put the Omega where it is just to avoid over-firing Clyde. I try to keep the indicated temperature under 500 degrees F. I don't overload Clyde - I never pack it to the gills - just enough to keep the house (2000 sf ranch) comfy. And then I adjust the air control so that Clyde is not burning too hot. I close the air down substantially to get a longer burn. I burn very dry wood - most of my wood has been drying for four years. So I get very little material when I clean the liner.
I have to be careful about running Clyde when it gets too cold ( I think that it hit -10F last night) because my plumbing runs under my floors in a crawl space. We have no basement. What we do have is laval rock. When Clyde is burning, the thermostats don't call for heat from my forced-air natural gas furnace. The leakage from my forced-air ductwork keeps my plumbing from freezing. So in more temperate conditions, I use Clyde to keep the gas bills low. Clyde's heat is very comfortable - much more so than forced-air.
Good Luck and have great 2017.
