Hello folks, my name is William an I just bought a house last month in Central MD that has a double sided fireplace. I hadn't really thought much about heating with wood but a strange sequence of events unfolded that are leading me in that direction. More about that later.
My immediate situation is this. I have a 1800 sf ranch with entirely below grade basement. I have a heat pump with oil fired furnace. I am looking to substantially supplement my heat with a wood burning insert. The fireplace centers between the family room and living room, i.e. not on an end wall. I would like the stove or insert to face the living room side as that is closer to the center of house.
I am considering an old sierra 4600 insert that I have but am concerned it will be a fuel hog, might be dangerous or my insurance will give me grief over it. My untrained eyes gave it the once over and i see no obvious, defects other than a pane of glass and some gasket needing replacement. I also have good access to free firewood from woodlot nearby but have to cut, haul and split...no biggie there other than time as i enjoy the physical labor.
The flue cap is 13.5' to the damper and about 16 to the bottom of fireplace. I realize that I need a liner, probably insulated. If i recall correctly the insert has a 6" outlet but there is only about 5 inches of space between the fireplace damper opening. Can i squish down the insulated liner or should i be cutting out part of the damper frame? Which liner should i be looking at, ridgid or flex? Any other advice or suggestions would be welcome.
Also do you think I'll be okay with the old sierra insert or should i bite the bullet now and get a modern stove? Im pretty limited on funds after the DP on the house. The chimney looks pretty good although i plan on cleaning it before i drop the liner. I'm also wondering what i should do on the back side of the stove where it would be visible to the family room. Block it off with something like cement board or just put a screen over the opening so i get some residual heat from it? I think i also need to pass the liner through some type of blocking board (cement board) near where the damper would have been?
I have above average DIY skills and common sense but this is all new to me and i want to figure out what I'm getting myself into before I take the plunge.
