Hey guys I have a newmac wb 100 I just installed its a older one I was curious if the blower fan constantly runs while burning or something is wrong the draft blower comes on as it should when it calls for it thank you
Microsoft Word - 2210058WBWGENG020110.DOC (chauffage.qc.ca)
Is this your furnace? Seems that you turn the draft fan on via t-stat until you have a good fire going then you lower the t-stat and the draft fan will turn off once its satisfied.
This is my Wood stove if I put my thermostat on 70ish the blower runs constantly and the draft fan seems to come on as it should when the temp drops below thermostat setting just curious if the blower is supposed to constantly run pushing heat through the duct work
