First off hello my first post but I've read many threads over here and learned quite a bit as I knew nothing about Pellet stoves.
After much research and some pricing I ended up with the Enviro M55. I believe I picked a good one so far works great as far as I can tell. I had two tons of pellets delivered for the up coming winter here on Long Island American Wood Fiber I hope there OK I see and hear about so many different brands. I will have to play around with a few other brands but these where easly available and not as expensive as some others. Country Boy , Thurmans, and New England are around but quite higher priced. Not really to sure of the differances til I try a few.
I did the install myself as I am in contracting so it was quite easy. I also built my own Hearth for around $40 in Material.
I do have a few questions maybe some can answer
First off I found some brushes and tools that came with the unit and didn't see what there exactly for.
But may main concern is the Flame pattern.
First what does the combustion air trim do ? Is this just to lite the Pellets?
Then the Feed Trim is this to increase or decrease the feed of More or Less pellets ? I thought that would be automatic with the fan increase when using the heat level?
I also notice that the left side of the burn pot seems to produce a more constant higher flame then the right side this has me baffled.
I watched the video on the flame pattern I believe its ok not as god as the video but that I asume could also be due to different types of pellets. I thought about messing with the slide damper but desided to give it some time. I am trying to get everything set so I get the most out of the unit.
Also is there Tech support Tel Number from Enviro?
Any help or advice would be helpfull Thanks Mike
I tried to post Picture but says the file is to large.
