I have been trying to get a better seal between my stove door and body. I seem to leak air from the bottom. I have done 4 replacements in the last 6 weeks. Some OEM, some aftermarket gaskets. Here is my latest with a brand new OEM gasket. The video shows how easy the bill pulls out. The pictures show the new gasket installed. I did not stretch it; I did not bunch it up (as I did in one attempt). I did not twist it. Also pictured is the gap between door and stove body without a gasket.
I have made two types of adjustments in an effort to get the gasket to seal. The first is to rotate the door handle one turn counter clockwise. This brings the door frame closer to the stove body. But, when I attempt to lock the door handle, it binds up. The handle starts to engage the locking mechanism when the handle is straight up. (In the 12 o'clock position). It is fully locked when in the 10 o'clock position. There is a lot of resistance right away ---at the 12 o'clock position. I have pushed with all the pressure that I feel is appropriate..before I feel something might break or warp. I can add more pressure to shutting the handle; it is just that I do not feel that is the right thing. I have contacted the manufacture regarding the amount of pressure that can be applied to the door handle.
I also adjusted the hinge side pins. These rotate which allows for the hinge side to be brought closer to the stove body. There is about .060" travel that can be used to bring the door closer. I tried various positions up to the .060" and the seal still fails the test. (The pins can only be rotated up to 1/2 way. Any more and the sections of the door that slide over the pins makes contact with the stove body and the door will not fully open.)
I also tried only rotating the bottom pin. No luck.
The bottom left corner is where the bill slides out. The other areas (top and sides) are ok. I do not see a bend in the stove body or the door that would overcome that much gasket material.
For those of you that have successfully replaced door gaskets on Drolet stoves, any thoughts?
![New Door Gasket- Fails Dollar Bill Test New Door Gasket- Fails Dollar Bill Test](https://www.hearth.com/talk/data/attachments/293/293681-a0a5182b3a24a3a801e085e9c6ed76fb.jpg)
![New Door Gasket- Fails Dollar Bill Test New Door Gasket- Fails Dollar Bill Test](https://www.hearth.com/talk/data/attachments/293/293678-56c2f611c2b8fef24ab02061a135009c.jpg)
![New Door Gasket- Fails Dollar Bill Test New Door Gasket- Fails Dollar Bill Test](https://www.hearth.com/talk/data/attachments/293/293679-7b0d51c37d70a7739cee1e8a21ceb9c0.jpg)
![New Door Gasket- Fails Dollar Bill Test New Door Gasket- Fails Dollar Bill Test](https://www.hearth.com/talk/data/attachments/293/293680-6a3b595c8491c69ead252923e63004ca.jpg)
