Hi all,
I am getting ready to put an old King 628 wood-stove (see here) into a 12' x 14' cabin to provide heat for fall and spring use. Cabin is uninsulated at this time. I am living on the land but am not the owner of the cabin.
The original builder of the home, a great neighbor, is a source of a lot of info for the owner. He came by yesterday and recommended going out the wall and up the side, using all stovepipe, cutting a 2' x 2' piece out of the wall and replacing with steel sheets (sandwiching some type of cement board maybe). He has run this type of setup a number of years and is comfortable with it for a short term, shoulder season, inexpensive option. We are burning hardwood (mostly ash) seasoned for two years, and would upgrade the chimney down the road if the cabin was made ready for 4 season use.
This seems unsafe based on my readings here, but I wanted some more feedback, and any thoughts on other inexpensive ways to install this stove.
The cabin has 10' walls and a 16' roof peak, sheet-metal roof, and a loft at 10'high which takes up half the room (12' x'7). Seems like cheapest safe install would be not under the loft, straight up with stovepipe and then through with Class A'.
Thanks for all your help.
