Greetings all, new member her and I've been learning as much as possible from past posts and hopefully I didn't miss anything obvious. I'm building an 1800sf new home in the West Virginia hills and I'm looking for a wood burning heat source mainly for the ambiance but also for if the electricity goes out. The unit will go in the corner and my preference is a stove in an alcove but I'm seeing a lot of issues related to clearance. Pictures are attached but the face will be about 5'6" wide. My preference right now is a Drolet Columbia II with the stove sticking out about half way beyond the face. My thought is to frame my alcove with steel 2x4s then line it with Durock and a non-combustible brick veneer. I believe this would give me 6"+ clearance around the sides with plenty of open air to exterior walls which are framed with lumber. The top of the alcove is where I see my biggest problem. I prefer a smaller opening so an alcove enclosure 6"-8" above the stove top would be ideal. Again it would be framed with steel 2x4s and either the Durock/brick veneer combo or just 24 gauge steel plate. My issue there seems to be the Drolet manual doesn't clearly define clearances for non-combustible alcove tops. I've reached out to Drolet and waiting so hear what they say but I'm guessing unless they put it in black and white, it will ultimately be up to the building inspector?
I did see that Lopi has what seems to me, clearer instructions on above alcove clearances, 6" for non-combustibles. I noted that for non-combustible alcove construction, Lopi requires 3 1/2" of non-combustible material. They cite, brick, stone and concrete as examples but would I be able to stack several layers Durock to achieve the same level of mass?
Finally, if I simply can't get my wood stove in the alcove, would a zero clearance wood insert be my next best option? I just started looking at them (not wanting to accept defeat on the wood stove just yet) and while I'm not crazy about the cost, it seems like the Lopi Evergreen NexGen Hybrid Insert would fit in my enclosure and it does not seem to have any clearance requirements that I can't meet.
Thank you all in advance, I look forward to the responses!
Mark
Mark
