Hi there,
First time poster here. We’ve been heating with wood stoves for the last 15 years and currently have a 2200 square foot house with a 20 year old Pacific Energy Summit. We also have a mini split heat system with three zones in the house. We tend to use the mini split until end of Nov then switch to exclusively wood heat until end of March.
The Summit is starting to get worn and I’ve been filling a few small cracks with high heat cement. We are considering buying a new Blaze King Scirocco 30 or Chinook 30. Main draws to the BK are less wood, maintaining more constant temperatures and avoiding spikes.
But I’m worried about draft. If we put in a BK the double wall pipe would come up out of the stove for 26” (Just slightly more than the BK min), then 90 into a masonry chimney, then 90 up into a stainless liner that lives inside of a brick chimney. Total length of chimney is about 16’ from top of stove. The brick chimney does not have a tile liner, just a stainless pipe in the brick chimney.
The summit currently burns fairly well but I do have to clean the chimney 2-3 times per winter depending on how much we burn. Roughly every two months if we are burning 24/7. For wood we use 1-2 year seasoned Douglas fir and big leaf maple. We have a good woodshed and try to stay a year ahead of our needs.
Do you think this setup will work and provide enough draft with a blaze king? I would hate to invest $4000 CAD to find out it’s not enough draft.
Thanks for any advice!
