We have battery maintainers and a older booster pac, I was wondering if anyone has a the newer style like a NOCO and what they think about them.
Thanks @ABMax24 , do you recall what model number you have?I have a NOCO charger, I really like it, much better tech and charging algorithms than most chargers. Mines not the booster pack though. That being said I know a few guys that have them, and they've all said they'll never go back to the standard lead acid booster packs.
You can't use this like a booster pac?The kicker with NOCO is you still need a dedicated charger, and separate booster pack. It would sure be nice if they built a combination unit.
Amazon product ASIN B07W3QT226
I see this model is a battery charger.
Amazon product ASIN B016UG6PWE
I was looking for a booster pac/battery charger that could go with me in the woods, I was stranded once on the hottest days of the year on our highest hills.
Which model number would have the best chance of bringing back a battery with a bad cell?
Dual batteries if you are in that position lotsThat's just a booster pack, not a charger.
I've never been able to bring back a battery with a dead cell. When I get a dead cell its usually because of a short.
I rely heavily on my batteries to be functional, many of the places I go could be life threatening should my equipment not start. I use my NOCO to keep my batteries in good shape, but I won't dare push a battery past it's prime. I guess a booster pack would be added insurance, but I think I'd forget to keep it charged.
The reason I was looking for a new type of battery charger is after 13 years with the original battery, the Rhino has gone through four batteries in about three years. I've had each battery on a It's Battery Tender Plus since the original battery.Dual batteries if you are in that position lots
What are your thoughts on the NOCO 10, it will be the 5 or the 10.At 10 amps, which won't really do anything.
I went with the 10, it should be here next week. The new battery for the Rhino is an AGM from NAPA but I'll need to take a look at the truck, car and the rtv battery so I can get the proper setting on the 10 before charging.Either/or, the 10 amp charges twice as fast and can supply 12volt up to 10 amps should you ever need it to power something with it. and has the 6volt agm mode.
I went with the 5 because I'm not usually in a rush to get a battery charged, nor did I need the other features.
On/off battery switch is the simple cure for that problem. You could end up pulling your hair out over a phantom discharge, especially in a vehicle that old.The reason I was looking for a new type of battery charger is after 13 years with the original battery, the Rhino has gone through four batteries in about three years. I've had each battery on a It's Battery Tender Plus since the original battery.
Its got to be something electrical going bad on the Rhino, the new shop I have looking at it has ordered a new main switch assembly, he said when he shut it off the Rhino kept running. He has checked out a bunch of different things he thought could cause it and they're fine.
He will put a new battery in it (from NAPA) once the new switch has been installed plus I have a another new one here. We have the tractor and the RTV so I can still get some work done and the new part hopefully will get here before or after Thanksgiving.
The Yamaha dealer where we bought it shuts down from November - March.
I had never thought of that, thanks rotti.On/off battery switch is the simple cure for that problem. You could end up pulling your hair out over a phantom discharge, especially in a vehicle that old.
