Please be patient, first time poster needing some basic info. Searched thru the posts but still need help.
I have a large dutchwest wood stove with catalyst and I don't have an owners manual for this unit. We have thermostats on the flue going into the ceiling, one built in to the unit on top (for catalyst?) and another on the woodbox door. I've read the do's and don'ts on this website but do still have some even-more basic questions. Here goes:
How do I engage the catalyst on this unit (Dutchwest XL Model 2462 wood stove) or does it engage automatically? There is a knob (turns like a screw) on the side of my unit that I think has a connection with the catalyst??.
Info on burning a fire in this unit says to operate it in 'bypass' mode initially before engaging catalyst but be careful not to overheat the stove. How do I keep this from happening?
We use this unit to heat our home (2400 sq ft) but I feel I'm not using it's full potential. Guess I'm scared of burning the house down in our sleep! What do (all) the thermostats need to read (how hot) before I panic and shut it down? Thermostat on the firebox says its in the 'burn zone' and I keep it there except for the times it drops low then I add a log and open the damper. I add a log or two usually in the middle of the night but I'm always having to adjust the damper to keep it in the burn zone.
How long (days) can I keep the fire going with catalyst engaged (once I learn to do this). It's been great having a fire these past couple of weeks - the heat hasn't had to be turned on - but I'm going thru a lot of wood, making a lot of ashes and it's a little high maintenance. Again, I feel once I learn about the catalyst I can tap into this stove's full potential.
And lastly, is the only time I should close my flu when I am not burning a fire??
Thanks for any help :0) Sorry for the long post...
