NEW ASH VAC
Boorus
29
Michigan
GOOD MORNING. LOOKING TO REPLACE MY ASH VAC WITH EITHER A POWER SMITH PAVC 102 OR A PELLETHEAD. THERE ARE A LOT OF COMPLAINTS ABOUT THE POWER SMITHS MOTOR OVERHEATING AND NOT LASTING VERY LONG. THE PELLETHEAD SEEMS TO HAVE FEWER ISSUES AND A MUCH LONGER WARRANTY AND IS RATED SLIGHTLY HIGHER. I PLANNED ON BUYING THE POWER SMITH BUT NOT SURE NOW. HOPING TO GET SOME ADVICE. THANKS
For the small amount of ash from a pellet stove the powersmith for me works fine. Cant see buying a big horsepower unit for that. Maybe a woodstove. It did ovverheat once in me when i used the small plastic tube attatchment for getting in a small area like the ignitor compartment. It shut off but after 20 minutes it was working again. Prob too much coming thru the small diameter of the plastic tube. Think i bought that tube as an accesory. Bad design. Using 3 yrs now and never conked out again.
  • NEW ASH VAC
I too have a PowerSmith ash vac. It's 3 or 4 years old. Works fine. Use it for my fireplace too. Would buy it again. Menards has one also for about the same price. Can't vouch for it though.
My power smith is more than adequate for the pellet stove.
I have a Cheetah 2 that works very well for my cookstove and wood stoves.
The Power Smith is great! If you keep all the filters clean then it will last a long time, that is key.
Parts are easy to get and easy to fix!
I like the easy to clean bag filter and when you get a hole, just pop in a new bag and it sucks like new!
Pics of mine
The On-Off switch finally died and I popped in a better one from Home Depot. $5 !!
See pics
I just use a small vacuum from my local canadian tire with a stainless can and bag... Been working great all year with no issue.. Picked it up on sale for about $30 so for me that was a much better alternative instead of spending $200 on a ash vac..
I went to my local hardware store and bought a 5 gallon Shopvac with a bag and a HEPA filter. The filter cost as much as the Shopvac itself.... but I haven't had any issues. And if I feel like it I can put the original filter on and use my Shopvac to do other Shopvac things...
Initially I didn't have a bag, which was a mistake. I'm not sure if I need the HEPA filter now that I have the bag, but I can't return the filter, so....
All I ever used is a Shopvac with a fine dust bag(drywall dust)
on both my pellet stove and my wood furnace. never had a problem
Reactions: Ssyko
