I've been running a new Nepolean S25 non cat stove for about a month and am having trouble keeping the temps and burn time under control. Any medium or full load will burn pretty hot and fast with stove top temp maxing out in the low 800s despite shutting the air all the way down as early as the fire will allow and stove top temp well below 500. The manual says to keep stove top temp under 700. Stove is in a large 750 sq ft room with 14 ft cathedral ceilings, room temp regularly gets into the 80s and I cant seem to get a burn time over 7 hours or so.
Last nigh I loaded it up with large splits of ash over hot coals. I shut the air down early to prevent over-firing and it took a long time for the wood to completely catch but was pretty intense once it did with strong primary and secondary flames over 2 hours after loading. I believe I'm getting too much air unless I'm doing something else wrong. I have a 21ft duratek double wall chimney with one set of 30 degree elbows in the attic. Where do I check for leaks besides the door? Will a loose connection or leak in the chimney affect the fire in the box?
