Hello everyone! In our house in northern New England, we are dealing with some negative pressure issues that cause smoke to enter our full basement while running our fireplace on the first floor. Here are some pertinent details:
I understand the basics of what is happening here (please correct me if I'm wrong) - the fireplace needs a ton of air, and is grabbing it from the only place it can in our tightly sealed home: the boiler's flue. Obviously a previous owner had this issue as well and installed the outside air kit. We have also gone crazy with silicone sealer on the boiler trying to fill any gaps we can find in the ducting elbows & junction with the chimney. Why isn't this solving the issue? What else can we do?
Thanks all!
![Negative Pressure - Any ideas? Negative Pressure - Any ideas?](https://www.hearth.com/talk/data/attachments/290/290676-8793837be9d9fc28318fddfa7ca95c8f.jpg)
- The fireplace is on the first floor and has an ash catch running down to the basement.
- The fireplace utilizes an outside air kit that comes in through the ash chute. We only run the fireplace with this open.
- The masonry chimney contains two separate flues, one for the fireplace, the other for an oil-fired boiler in the basement.
- Both flues have their own ash catch in the basement, on either side of the chimney. They appear to be separated by masonry of some kind.
- Both flues exit the chimney at the same height, under a large stone cap that sits maybe 2-3 feet above their exit supported by four corner posts. I attached an example photo (this is not ours, just something I found that is comparable)
Thanks all!
