Ok , building another house and the wife seems to think the days of hauling, cutting, splitting are over. I would have to buy wood at the next location never had to do that before. So if YOU were getting a gas (propane) stove to help heat the house what would you pick and why? The new house will be 2000 sq. ft...time to downsize
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
Thanks for all the advise because I have only owned wood stoves..
Well everybody has their best.
So...here is mine (ha) If you are building new I agree LP is Outrageous cost to value...but.. its clean easy and available.
We just built our LAST house and put in for the secondtime the following. 1676 sg ft open loft. Primary is a wood via a Masonry Heater. they rock and little to not much ash evr so wood issues none.
We are well Seasoned people, meaning older and hauling wood etc. sucks but the heater uses 40lbs per fire and with temps zero this year, 1 fire per 24hrs is all and we are fine. The crap about masonry heaters too hot for a super insulated home is wow wrong. they output constant heat regulated by the fire you put in. We have R-30 walls, R48 roof full end wall glass and well its awesome ..price is not as bad as some will say, a core like( not recommending) from tempcast with YOUR own brick outside was under 6000.00.
Gas we have had gas for years and between VC majestic and Jotul I have to say Jotul has been and currently is the best we have had through 4 homes.
Why well VC was very good but did need minor stuff too often, too early like 2 yrs in and more. The VC was nice yet the Jotul tops. The jotul we left at the old house 9yrs old Sebago much more heat with less fuel heated 1800sg ft with a Heat glo 42 fireplace in my office for my peace of mind and soul and Nothing wrong
ever just warm efficient Our one Majestic worked well BUT was a blaster always too hot then too cool poor regulation in the enclosure again just opinion. again issues repairs all minor but.....Our three Jotuls honestly NEVER had an issue, and no I don't work for them or anything like that.
We use the gas as a back-up when if we go away for more than 24hrs. I don't know if this helps but I too did not want wood issues as getting older but the masonry heat is wow, no work 2.75 full cords thats it in well its cold here longer.and my wife can bake at 375 6-8hrs yummy
Good luck on the house it is worth the hassle
