I am about to install my stove and need some help. If I am not mistaken NFPA211 allows you to cut the manufacturers clearances in half. However I recall seeing something that said the minimum clearance to combustibles is 12". I am installing the Harman TL300. The spec sheet can be seen here (broken link removed) . I would like to get 10 inches at the back of the stove but will settle for 12". My problem started yesterday when I spoke with the inspector and he said what ever the manufacturer says is ok with him. Problem is Harman says nothing about reduced clearances. He then suggests just call the manufacturer. Ya rite! Anyway the dealer says all I need to do to cut clearances in half is the 1" space behind the durock. This is what I was planing. Sorry if this is wondering around a bit. I wanted to get it posted before some of you left for work this morning.
Anyway. What I would like from the group. Can you provide me with some info that I can present to the inspector that show 12" or even 10" is ok.
If I am not mistaken this stove only requires spark protection for the floor (no R value). Please see the link above if you have time.
James
James
