I have a two-story with basement,square floorplan...imagine a rubic`s cube. Basement has fireplace directly under fireplace on first floor located in living room, both flues inside common chimney. Downstairs has central unit AC, Gas. Wouldn`t moneys spent be better spent on an add on wood furnace that can be ducted in? You boiler room guy`s are way ahead of my knowledge curve;so any help would be appreciated. Location is southern Ill. so my burning season is rather mild compared to many(3 to 4 ) months top. not many days in the teen`s.
Currently using pre EPA insert upstairs...and once fired my central heat seldom kicks on . however the burn times on this burner are not long so early morning usually requires central heat until I get up. Needless to say, If I`m going to do all the work associated with burn`s...why not have a few more room`s more comfortable? Fire Chief and Vogelzang are the two I came across today, could use some input on these and others. Please and thank`s.
