wendell said:I have a 3000 sf 2 story house including the basement with a 90,000 BTU high efficiency NG furnace which sits on the original pad. Currently, my wood stove is using the existing utility chimney with a 6" flex liner that is coming in from the opposite side of the original opening. I'm in town so doubt anything can go outside. I also have a tankless water heater.
wendell said:Yes, it is a forced air system. Although I would like to keep the stove in the basement the only way I could see this working is to pull it out and use the chimney for the wood furnace. My other option is to add a second wood stove so I'm not looking to spend much more than that would cost so most likely a boiler would cost much more?
wendell said:What are the advantages of a gasification boiler as opposed to just an add on furnace like a product from Yukon Eagle?
WoodNotOil said:wendell said:What are the advantages of a gasification boiler as opposed to just an add on furnace like a product from Yukon Eagle?
Two options for wood furnaces would be the Yukon Superjack and the Caddy EPA wood furnace. Both run in the $2500 range and have secondary combustion making them more efficient. I haven't seen the numbers so I can't say whether they are as efficient as the gassification boilers or not.
The advantage I see of the boiler with air to water hx is the ability to add heat storage to increase efficiency and store heat for when there is no fire and for off season direct hot water. Direct hot water is definitely a benefit. Also, you can add radiant heat to your house, garage, additions, etc. Gasification boilers however start at around double what the above mentioned furnaces run. Plus the heat exchangers, plumbing, and eventually the cost of setting up heat storage. I think it is worth it in the long run. Compared to the cost of burning fossil fuels, these systems usually pay for themselves in just a few years.
wendell said:How does the add on hook into the existing furnace? I assume that when the thermostat calls for heat, air into the firebox is increased and the heat is pulled from the add on? Where does it need to sit and how far from the chimney can it be? Will the existing 6" flex I already have in my chimney be OK?
wendell said:Thanks for that info. I have a 90,000 BTU furnace so had assumed I would need at least the same. I think it was on Caddy's site that said the Mini would only do a 1500 sf house. How do you figure the BTU's you need?
