Need info on timer relay.
RDealy
7
Snohomish, WA
I have a 1988 Breckwell p24 pellet stove. The timer relay started just running the timer relay (auger) full bore. I haven't had any luck finding a exact match on the relay part #. Can anyone recommend a part that will work the same? I havent been able to find a cross referance anywere. Thanks.
  • Need info on timer relay.
This may be a workable solution, but it might be cheaper to replace the stove. It will need to be programmed to work with your stove and it should plug in.
Amazon product ASIN B007ID7OXI
