Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
I have to replace my stovepipe and chimney on an old wood stove in a home I purchased, is there a place where I can buy a kit to do this or so I have to piece everything together individually? Thank you
Will you be relocating or replacing the old stove and putting in a new metal chimney at that location or just replacing what we see here.
The old Earth Stove does not look like it has proper clearances.
If just replacing what is there, yes, there are kits that have most of the parts one needs. These are sold online and through the big box stores like Home Depot. Often they are with value line chimney. If you want a better grade it's best to buy the parts separately, but the kit will show you what is used for the job. The kits will not include the actual chimney pipe which will vary with the height of the installation.
For example, this is with DuraVent's DuraPlus value line of chimney. The better product is DuraTech.
(broken link removed)
Sounds good. It will need to be at least 36" from combustibles unless the stove has the UL label on it with closer clearances. The red tile wall behind it is not a proper wall shield. The clearance can be reduced to 12" with proper wall shielding. Here is a primer on the topic:
Thank you I just have been having lots of trouble finding 8” kits on any big box store websites and I want to just use chimney pipe on the exterior no chimney after I tear the old one down
Download the installation manual for installing DuraTech chimney. It's well illustrated and will answer many questions. This is a good site to order from. Ask for Sean to help you put together a package: www.woodstovepro.com
