Hi All,
We just purchased a st croix prescott. When I cleaned it tonight, I noticed that the piece of metal running along the bottom of the stove door was a bit loose. Upon further inspection I found a loose screw. This piece is held on with a screw on either end and a small bolt in the middle. When I went to tighten the screw I found it was stripped. This stove is new and under warranty but I am wondering if there is an easy fix (lock tight or other suggestion). It seems that the door seals tightly but I am worried about running the stove now. Has anyone had an issue like this or can you give me some advice? Thanks!
