My wife and I bought a really neat contemporary-style home this summer that came with a standard fireplace in our bedroom and a fireplace insert in the great room. I'm still young enough to manage wood duties, but I'm getting too busy with work and found a great deal on a pellet stove insert on Craiglist. Pellet stove works great, all ready to go, but I can't get the fireplace insert out of the wall.
Unlike some of the smaller inserts, this insert looks to be taller than just the firebox. I cut away some small pieces of drywall behind the molding around the insert, and a small soon-to-be outlet box on the side and I can see that the box goes up about 5' or 6' up the wall. Luckily the chimney is just a sheetrock chimney with an insulated stainless insert that goes all the way up, so I can easily get to the insert if I cut away at the wall, right?
I can't tell what make or model it is, but the house was built in 1987/1988. There are two blowers underneath that push the air behind the stove and out the two vents that you see at the top.
So, is it possible that I can cut away at the drywall, remove any 2x4 braces, and pull this insert out? Or were these inserts designed to be taken apart in two pieces? As of right now, it doesn't budge at all when I pull on it and I can't see any fasteners inside.
I have included a pic (I'm messy, I know!) that might help. Thanks in advance.
![Need help with removing huge fireplace insert (pics) Need help with removing huge fireplace insert (pics)](https://www.hearth.com/talk/data/attachments/127/127101-39f4984c1685f7f13bd6fc4055ddd9bd.jpg)
