So, the chimney sweeps were here today, and I wanted to learn about how to access the flue to clean it from the bottom. I am having trouble figuring out the Morso manual, with its blurry pictures. Got the baffle out, and it is now sitting in the bottom of the stove- there was a pile of soot from the cleaning on top of the fire blanket (which I didn't know was there). This makes cleaning from the top down suboptimal, in that you cannot get the soot out, unless you detach the baffle. But to clean from the bottom up, to gain access to the flue, you still have to remove the baffle. It's quite a production. I took out all the bricks because I didn't want to drop the 30# baffle on them, but I'm not sure that that's necessary.
Anyway, the 4 bolts holding the baffle to the rear of the stove are out, and the baffle is sitting on the floor of the box, but there don't seem to be any guide bolts, like the manual says should be there. I'm hoping people can help me by looking at this picture:
The red arrows are where the baffle screws in. I'm wondering if the blue arrows are where the guide bolts are- there are holes with threads, and a headless bolt screwed in deeply. The picture in the manual (page 7, second photo, here: http://www.morsona.com/Files//Files/PDF/Manuals USA/72560400-5660_NA.pdf) is very unclear. If the blue arrow holes are where the guide bolts are supposed to be, I guess that means I have to pull the insert out to get to the back of the firebox and screw the bolts in toward the inside so that the guide bolts can be used. Is that true? This manual is LAME. And pulling that whole thing out to screw the guide bolts out is going to be a huge production.
Finally, I noticed a light coating of rust on the inside of the box. I'm no longer going to put wood in when the box is cold, to be ready for the next fire, but is this the cause, or does interior rusting happen anyway?
![need help with reinstalling baffle on Morso 5660 insert need help with reinstalling baffle on Morso 5660 insert](https://www.hearth.com/talk/data/attachments/152/152647-70f005805a422f464904ae22422019b9.jpg)
