I just acquired a nice used jotul and I cannot wait to use it. Wife says I need to do a professional install but I am not having any luck finding anyone to do this. I was thinking I could do the install and then have a chimney sweep inspect it. I would think the install would be fairly straight forward and save some money. I plan to place the stove in my fireplace and have it exit through the chimney. I checked out the black pipe at lowes and they seemed to have all the pieces but they could not tell me the gauge. I was told to use 20-22 gauge. The install directions say that the flue cannot exceed 8x12 and mine measures 10x10 so I'd assume my chimney would work. I plan on using a tee connector then running a straight pipe upwards a foot or two. I would then put an elbow since the chimney does not go directly up. After the elbow I would add a straight piece until it met or goes into the flue liner. I would get a metal shop to make a piece to seal off the bottom of the fireplace but I am not too sure how I would secure that to the brick. Am I anywhere close to being on the right path with this? Any help or comments would greatly be appreciated.
