My family has an old Crossfire FS-1 made by Thermic in 1988. We got the stove maybe 3 or 4 years ago I think, and once I overhauled it, it seemed to work pretty well, with minor quirks, until now. The exhaust/chimney setup is kinda cobbled together and I am unsure how exactly it was originally configured or supposed to be setup. When I overhauled the stove, it initially came with a dual function blower that handled both the exhaust and the force-fed air for the combustion chamber. I accidentally damaged the motor when trying to disassemble it and was unable to locate a replacement so I ended up ordering some more readily available blowers so now it uses two separate ones too push air in and draw exhaust out plus the fan to move air over the heat exchanger.
It started building up a very wet condensation or creosote in the chimney which runs down into the exhaust blower which blocks airflow and causes the low vacuum alarm to sound and it also leaks out the chimney pipe joints which I believe are upside down from what I gather. this happens about once a day. I also noticed that the pipe is only luke warm and it normally is hot to the touch. Im also aware that the exhaust being routed up an existing chimney from a woodstove may be done wrong, any pointers would be appreciated.
![Need help with an old Thermic Crossfire Need help with an old Thermic Crossfire](https://www.hearth.com/talk/data/attachments/310/310420-882185d021b0e7db7ef1beaf07e768db.jpg)
![Need help with an old Thermic Crossfire Need help with an old Thermic Crossfire](https://www.hearth.com/talk/data/attachments/310/310416-36ae1f53b2fe0f37e16f71cfec189095.jpg)
![Need help with an old Thermic Crossfire Need help with an old Thermic Crossfire](https://www.hearth.com/talk/data/attachments/310/310417-1d294794fee483912d74d089e5d01a77.jpg)
![Need help with an old Thermic Crossfire Need help with an old Thermic Crossfire](https://www.hearth.com/talk/data/attachments/310/310418-8ab74094d538a936f6c1b1865b19178f.jpg)
![Need help with an old Thermic Crossfire Need help with an old Thermic Crossfire](https://www.hearth.com/talk/data/attachments/310/310419-8cb28110281c28bc52dd84611913e925.jpg)
