Hi everyone. Hope everyone is well and getting ready for burning soon. I'll try to make this short. I am looking to purchase a new wood stove as my primary heat source and was hoping to get some of your help and opinions. I currently own a PE vista and it does a great job of heating the place. But the burn times are way too short and it puts out too much heat all at once. I'm tired of constantly reloading it, then after sleeping or getting back from work there is no coals left to restart the fire and the place is freezing cold. Lots of times a have to make two fires a day. It's such a challenge to heat a small place!
I think a stove that would be capable of putting out heat at a lower steadier rate and that had longer burn times would solve a lot of my problems. I researched and found that a catalytic stove would fit the bill. I also would need a tight clearance stove. After researching I'm really having my heart set on a Blaze King Sirocco 20 or 30. I'm a little intimidated because I've never owned a catalytic stove but I'm willing to learn. I was all set to get the Sirocco 20 when I saw that it only takes 16 logs max.(can anyone confirm that? Is that east to west or north to south? And can you load the other way?) All of my wood is a average of 16.5 to 18 inches. So I would have cut all the wood to 16. Will true 16 inch firewood be difficult to find? I don't want to have to go through the cords year after year cutting all the slightly oversized logs. Or do I get the Socorro 30, which can take 18 inch logs. My only problem with the Sirocco 30 is will it be too large for my small place? I'm worried that I'll never use it on the higher settings and have a lot more creosote build up. Any opinions appreciated as soon as possible before all the sales end.![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
Area I'm trying to heat is an insulated second floor of about 800sqft with 8ft ceilings. Below is a unheated and uninsulated garage. Above the second floor is small uninsulated attic. The stove would be in the 20x12 living room in the corner. I have about 15 1/2ft of chimney total. About 5 feet of DVL double wall from stove to the ceiling. The rest is insulated double wall class A. About 3ft resides in the attic and 7ft is outside the roof with no chase. I would probably need to get two 45 degrees DVL's to pull the stove a few more inches away from the corner to meet clearances.
Opinions? Thanks again for everyone's help.![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
