First let me preface my post with the fact that I know very little about wood stoves in general. My wife and I moved to a country home 2 years ago that uses a freestanding wood stove as the main source of heat, and we love it. It has been, however, my first experience with a wood stove, so it has been a learn-as-you-go experience.
Currently I am trying to set up an older wood stove in my shop. The previous owner had a stove in there that he took with him when he sold the property, so there is already a chimney insert in the roof (not sure what this is actually called, but there is a 6" pipe surrounded by a metal box that passes through the roof). My dad gave me an old stove they used to use in a shop. It's simply a square metal box with no legs, which I believe is an insert type stove designed to go into an open fireplace. I'm trying to figure out how to use this as a freestanding stove in my shop, but I've run into a few problems.
The biggest problem I have is that the opening on the top of the stove is rectangular rather than round, measuring 9.5" x 5". I have tried a few of our local wood stove and farm supply stores, and nobody has a clear idea of how to hook it up to a 6" stove pipe. One shop owner told me to have a custom adapter made at a sheet metal shop. The fellow at the sheet metal shop recommended I try to use a larger stove pipe and, using a hammer, attempt to shape one end of it to fit the stove top, as a custom made piece would probably cost over $100. That sounds a little sketchy to me, but only because I have no experience setting up a wood stove and the last thing I want is to burn my shop down.
I would like to save as much money as possible on this project (obviously using a hand-me-down stove and the old chimney fitting, I'm looking for a very low cost setup); however, I'd rather spend a little money on something if that's what it takes to ensure safe operation of my stove.
A few other details that may or may not help: I plan to set the stove on some cinder blocks to lift it off the shop floor. It's a small shop so I don't do any automotive/tractor maintenance or anything, but I do store oil and chainsaw gas and whatnot in there so I don't think I want it sitting on the concrete floor in case of spills. Also, the only identification of the stove I can find are the words "The Yellowstone Stove" on a gold colored circle on the front of the stove where the air control is. The stove shop owner recommended I look into the brand of the stove to see if they made an adapter, but google searches for "The Yellowstone Stove" haven't been fruitful, and nobody I've talked to has any idea if any sort of adapter even exists.
I'm sure something like this must have been done before. Does anybody have any advice for me? Also, any suggestions about my general setup or tips or anything are appreciated, as noted earlier I am a wood stove noob.
Thanks in advance!
Joe
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
Joe
