This is important enough to me for a new thread to hopefully gather some attention and help. Everyone has been great here and I need help as I am somewhat stuck.
The liner in place for the installation of my Pacific Energy Summit LE insert was somewhat short. The prior installer should have gone 35 ft and going all the way to the unit. They did not do that ended up with an ugly 90° that we talked about.
1) The end of the liner is not round. I'm worried I'm going to have difficulty attaching anything to this? Any ideas about rounding it out or should I use a male adapter that inserts into the liner to prevent smoke from escaping? Perhaps would have to cut off the crimped male end of the liner.
2) it seems impossible to push the liner upward as it might be caught on the damper that might not have been cut sufficiently enough to pass the liner through easily. So I'm concerned when I get the unit in place I won't be able to push the liner and adapter out of the way. Any thoughts or strategies here? I hope I don't have to take off the block off plate.
3) I'm wondering if I should use a 6-in to 5-in adapter at the fireplace insert, and then place 5 in liner inside the existing liner for several feet. If you recall my setup has no problem with breathing and overdrafting was the issue so 5-in constriction I don't think would be an issue and actually a help. Any thoughts on this?
I really don't want to move forward without some guidance and suggestions because I could really screw things up here and need a new liner.
Hopefully with a picture will help. I really welcome some support here. I think this might be one of the last hurdles to a nightmarish few months of a unit that failed from overheating.
Thank you,
David
![20220507_145009.jpg 20220507_145009.jpg](https://www.hearth.com/talk/data/attachments/295/295428-4add2a8a698356902741405ac212e9f4.jpg)
Thank you,
David
