Hello All,
This has me boggled and I can't seem to figure it out. If anybody has any ideas, opinions or whatever kind of help it'd be greatly appreciated!!
I have an older CB-1200i with a manufacture date of April, 2001. The stove has provided me with years of great service, but this year it decided to give me a headache...
The stove was thoroughly cleaned at the end of last season and was awaiting this year's first cold weather. This year I went to turn it on and there was a red call light on, but no pellets were feeding. Pushing reset did nothing. The igniter does come on, but still no feed. Here are the tests I've done so far and what I've found:
Checked exhaust and it is clear through up the chimney.
Checked the snap disc on the side of the feed motor and it is ok and did not need to be reset.
Jumped the vacuum switch and the feed motor does turn on.
Disconnected the vacuum line at the feed motor and put vacuum to it and it did activate the switch and it does hold vacuum and turn on the feed motor.
Jumped the convection blower and it does work.
Jumped snap disc #2 and it does turn on and off the red call light, as does the thermostat turn on and off the call light.
Tested every possible voltage and tested for power at every place possible and all seems to be correct according to the service manual specs.
One thing I haven't done and don't know how to test for, is the door gasket and to test for a good vacuum seal around the door. How do you test this other than to replace it?
For some reason, I just feel that enough vacuum is not being created to activate the vacuum switch and start the feed motor...
The door gasket doesn't seem to be in all that bad of shape. I will say though that the adjustment screws for the door latches are completely screwed in and can't be made any tighter. Could this be the problem? Is it that the door isn't sealing tight enough and allowing enough vacuum to escape?? Can this be tested somehow? I will say that the vacuum switch doesn't require all that much vacuum to activate it and I would think that the door gasket has to be in dire straits to create that much vacuum loss but maybe I'm completely wrong too.
Anyway, if anybody has any ideas of what else I can try, I would appreciate anything because I'm pretty much stumped at this point... Thanks in advance for your help
--Fin
--Fin
