If dialog below is to unclear I think I can figure it out using 45 degree distance if I knew the following:
1. What is the distance to subtract from the 45 degree distance for the two 45 elbows on each end?
Is 3.54" per 45 degree elbow correct?
2. What does using a 90 elbow add to the length? Is 7.3" on each end correct?
3. Is 1 1/2 subtracted from each pipe and elbow for joint overlap?
Venting for Kozy Heat Slayton using 5x8 double wall Selkirk venting. I need verification this routing will
work.(see attachment) It appears to meet the requirements in the Slayton install manual. I could
eliminate the second 90 elbow after the FP and replace it with two 45's if I could figure out the math.
I plan on using Selkirk as it fits with out an appliance adapter. I would like to use standard pipe if
possible, there is a 4-10" adjustable vent if necessary. 1" clearance from combustibles. Here are the
numbers necessary to do the math. horizontal from FP Vent connection O.C. through wall =18 3/4".
Horizontal from garage wall to center of 24" O.C. garage rafter is 43". Total horizontal run would
be from FP vent connection O.C. 18 3/4" +43"=61 3/4". Vertical from FP vent connection to bottom of
top sill on interior wall is 42 1/2". Add 3" for a double sill to 45 1/2" from FP to bottom of Garage rafter.
The garage rafters are 24" o.c. and run parallel to the FP.
![Need help Planning Gas FP Venting Need help Planning Gas FP Venting](https://www.hearth.com/talk/data/attachments/104/104971-421af036aeab29a0c87d51f78d5ef6f9.jpg)
