Hi all,
Newbie to wood stoves and to the forums.
Please forgive any ignorance.
I'm helping my son install a wood burning stove in his house.
It's an Englander 30-NCP.
Question regarding wall clearance. Corner install.
We removed all of the drywall a little over 6' from the corner on two walls.We built a hearth out 2" x 6" standard wood. We put down a 1/2" fire board (some kind of fire retardant particle board), 1/2" micore 300 and then 1/2" duroc "next generation" cement board topped by 1/4" ceramic tile. I'm pretty comfortable with this set up.
On the walls, same set up without the 1/2" fire board, with 1/4" ceramic tile. I did read before hand that it's recommended to have a 1" air gap for maximum protection. If you don't do this, the protection distance reduction isn't as much. We didn't. I found a few "r" value tables on the net and I calculate the value to be at 1.94 with sheeting, thinset and tile. The stove calls for 1.5. My question is, what is a safe distance for the stove pipe? The manual contradicts itself (at least from my standpoint) in terms of wall clearance for corner installation vs straight against the wall installation. 20.5" vs 16" respectively.
