Hello all,
I am building a new construction house and had a kozy heat Albany ZC fireplace (similar to their Z42). Local fireplace shop installed it. I posted earlier about venting the chaise until I realized the attic insulation shield has a big "vent" in the top of it already which dumps the heat into the attic. See attached pictures. The pipe on the left is the pipe from a basement gas fireplace. The pipe on the right is the outside combustion air intake. Someone in a previous thread mentioned of putting an "airtrap" as the original installers didn't do it. I verified in the manual and it did recommend it so I rerouted the pipe to include a small "trap".
I have most of the house sheet rocked and have been heating the house with the fireplace along with some electric heaters. However I don't know how I'm going to seal the chaise to prevent the house air from escaping from the attic shield 24/7 even when I am not burning. From doing some research, it seems that I'm suppose to have either a ceiling support box or a firestop? Can the firestop be caulked to prevent air leakage? Its aggravating I spent all the time air sealing all the electrical penetrations to only have this gaping hole in the ceiling.
Can anyone give me recommendations or if I am indeed missing something?
Thanks,
Austin
![Need help, Losing heat and think chimney is installed wrong Need help, Losing heat and think chimney is installed wrong](https://www.hearth.com/talk/data/attachments/293/293239-f831f0a9197e6a534948570fbd819128.jpg)
Thanks,
Austin
![Need help, Losing heat and think chimney is installed wrong Need help, Losing heat and think chimney is installed wrong](https://www.hearth.com/talk/data/attachments/293/293236-dc346dcb99d69950b74f0a385f385740.jpg)
![Need help, Losing heat and think chimney is installed wrong Need help, Losing heat and think chimney is installed wrong](https://www.hearth.com/talk/data/attachments/293/293237-bb110b12be3cc0f69e86925fa0bb8650.jpg)
![Need help, Losing heat and think chimney is installed wrong Need help, Losing heat and think chimney is installed wrong](https://www.hearth.com/talk/data/attachments/293/293238-e75c71a58f75cdab408a9e81e0a73307.jpg)
