I've been trying to answer my own questions, and not getting very far, so thank you in advance:
I'm building a log cabin, and want to install a wood stove as a back up heat source. Here are the specifics of my install:
1. The cabin is built on piers, with 2x12 floor joists, 3/4" subfloor. The finished floor on the left side of the stove will be tile, and 3/4" T&G oak on the other. In front of the stove will be the living area (and all oak floor in front, after the bricks), behind the stove will be an island that is part of the kitchen (mostly tile). I plan on installing some kind of approved heat pad, and then bricks on top of that, then the stove on top of that.
2. The stove is an antique parlor stove:
3. The flue is 6".
4. The ceiling directly above the stove (see pic) is made out of 2x12 rough cut cants, overlaid with 2x6 pine T&G. The cants are spaced at 24" OC. The distance from the interior of the stove flue to the T&G ceiling is 6' 5".
5. The distance from the unfinished loft area (2nd floor) to the 2x6 T&G insulated roof is 14' 8". The roof is built in a style known as "built up roof" or cathedral roof - the layers of the roof are as follows: 2x6 T&G decking (1.5"), vapor barrier, insulation (EPS foam) (8"), held in place with 2x10 "sleepers" (10") (yes, 2" air gap for ventilation between the EPS foam and top edge of sleepers), 5/8" OSB, tar paper, then shingles. The plan is to situate the stove so as to penetrate the roof, avoiding rafters and sleepers. The thickness of the roof is roughly 13".
In the photo, I drew in the stove pipe in blue. Sorry about the swing - my daughter needs something to do while I work on the cabin.
6. I'd like to do this economically, but also to code. It would be easy to have someone just come in and do it all for me, but I'm not that rich. I've built this entire cabin from trees I cut and peeled myself. I welded the support brackets for the 2nd floor, poured the concrete, built the doors from scratch. I'm pretty sure - given the correct information / parts list - I can figure out the stove pipe. The questions I'm running into is what parts do I need at the 1st floor ceiling, and at what point do I switch over to double wall pipe. The other question is what are the exact components I need to penetrate the roof besides the cathedral box (basically, through the roof parts, and the chimney stack itself)?
Also, this website says I can't interchange parts from different manufacturers for the same type of pipe (I can't use duravent and imperial brand single wall pipe in the same run) - but can I use Imperial single wall pipe and then switch over to duravent double wall pipe (and some kind of adapter)? That seems like it would fit within the rules.
Also, the pipe prices vary wildly - ebay, home depot, lowes, chimney pipe dealers, etc. trying to find the best price, too.
Can someone help me get a parts list together for the pipe?
Here's what I already know (correct me if I'm wrong / add to the list):
1. I can use single wall pipe from the stove to the 1st floor ceiling, then I have to use some kind of adapter and change over to double wall pipe.
2. I have to use double wall pipe from that point to the ceiling.
3. I have to use a cathedral box to get through the roof.
4. I have no idea after that.
Again, thanks in advance. Everywhere I go to ask questions leads me back here. But I can't find my exact question/answer here.
Best regards,
~mudflap
3. The flue is 6".
Best regards,
~mudflap
