Im not sure this is in the right forum, but It does concern my PE Summit insert. Im that guy, 1st season owner with the Summit insert that is blowing through wood and have a tough time heating my house with it. This is the thread that explains my ongoing saga..which many of you have been extremely helpful and patient with me.
So here on Long Island this morning we have some seriously blustering winds. Its around 15 degrees out and blowing a good 40mph. I went to load my stove this morning and I can feel from underneath the stove massive amounts of air coming in. As stated in the other thread, I do not have a block off plate installed (it will be done this summer). However, I noticed I only feel the air from underneath the stove...not around the surround. I would think if the air was coming from up the chimney I would feel it all over. My fireplace is stone so the surround is definitely not flush and has lots of gaps. I noticed that when the wind picked up and I hear the air rush in, I hear a metallic flap that sounds like it opens and closes.
Here is a video of what Im hearing from my end. Towards the end you can hear the flap. Its quite incredible the amount of air rushing in. I felt it from over 5' away.
So I went outside to take a look at my ash dump. I had stuffed some insulation in the ash dump but maybe it wasnt enough or maybe air was still leaking. So I open and pull the insulation. I reach my hand all the way up and I can feel the cover that would be inside the fireplace. It wont budge, so thats not the flap. I
I then noticed this on the outside of my chimney. What are these vertical lines? They seem to go in really far. Is this some sort of fresh air intake for a normal fireplace? Maybe so that you can shut the glass door and have it pull air from outside? If so, Im guessing this would be for pure aesthetics?
I took a look at my boiler and I believe the boiler stack is on the opposite side of these vertical bricks. You can see in this pick the smaller cap is the boiler and its opposite the fireplace chimney.
So my question is if anyone knows what these vertical lines are for? Is it safe to seal ( Im worried about carbon monoxide)? And what should I seal it with? Will silicone be OK or should I mortar them up?
![Need help identifying these vertical bricks on my chimney Need help identifying these vertical bricks on my chimney](/talk/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FA5yoJeN.jpg&hash=05a595f0e016999eb994a1c163068e1a)
![Need help identifying these vertical bricks on my chimney Need help identifying these vertical bricks on my chimney](/talk/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FuonZCKY.jpg&hash=5caa3ef8003e842ae4f8d66e8e14d6fa)
