Hi,
I am new to wood stoves, so I am reaching out to the experts for help.
I recently purchased Woodstock Soapstone Absolute Steel stove. Unfortunately the stove / setup is not working well and I do not know what the issue is...
The issue:
When I try to burn paper in the stove, it burns well and there seems to be a draft when the door is open. When I close the door, it burns for a little, flame dies and the whole thing goes up in smoke. In fact, the smoke is coming our from the air intake vent too, which is very strange. It just seems that the stove is not getting enough air, even though the air intake is open at 4 setting. I also keep the catalytic converter up, just as you see in the pictures. My pictures show the setup as tested.
My setup:
The only option I could think off right now is to drill 2” holes into concrete hearth and to drop the stove 2”. If I do that, the ash pan heat shield will be almost touching the concrete.
Please let me know if you have any ideas? What I am doing wrong? What should help? Is the stove working well; how can I make sure of that?
Thank you very much!
K.
![Need Help! I am stuck in smokes! Need Help! I am stuck in smokes!](https://www.hearth.com/talk/data/attachments/186/186981-0c916c6d76f45d245cd0ece586fbc609.jpg)
The issue:
My setup:
- Chimney - outside, 8” diameter, clay flue liner. Total height somewhere around 10-11 feet.
- I checked the chimney draft without the black pipe. it burns and sucks air so well, it’s whistling.
- One small issue is that chimney flue is about 2.5” lower than the stove exit pipe. I mitigated that with a single elbow and then straight black pipe going towards the chimney.
K.
![Need Help! I am stuck in smokes! Need Help! I am stuck in smokes!](https://www.hearth.com/talk/data/attachments/186/186972-c6587a189445594a9194af8350a40e6e.jpg)
![Need Help! I am stuck in smokes! Need Help! I am stuck in smokes!](https://www.hearth.com/talk/data/attachments/186/186973-71bb11dd22d0d6764ec4e239e32da4af.jpg)
![Need Help! I am stuck in smokes! Need Help! I am stuck in smokes!](https://www.hearth.com/talk/data/attachments/186/186974-77ff615962e5cb45da4da8b717d38873.jpg)
![Need Help! I am stuck in smokes! Need Help! I am stuck in smokes!](https://www.hearth.com/talk/data/attachments/186/186975-1d0cee4b9b7f69e8ee9645a1828d5f99.jpg)
![Need Help! I am stuck in smokes! Need Help! I am stuck in smokes!](https://www.hearth.com/talk/data/attachments/186/186976-be859da0faa390d3b3abe47eb295ba32.jpg)
![Need Help! I am stuck in smokes! Need Help! I am stuck in smokes!](https://www.hearth.com/talk/data/attachments/186/186977-eb9bb8d7228b804180454feabafd2304.jpg)
![Need Help! I am stuck in smokes! Need Help! I am stuck in smokes!](https://www.hearth.com/talk/data/attachments/186/186978-13863884b70f3e672c7aa4daaf8ab03e.jpg)
![Need Help! I am stuck in smokes! Need Help! I am stuck in smokes!](https://www.hearth.com/talk/data/attachments/186/186979-0e28d350b5a43f5da735070c6d55f495.jpg)
![Need Help! I am stuck in smokes! Need Help! I am stuck in smokes!](https://www.hearth.com/talk/data/attachments/186/186980-4bc1c3cf9075cfa5d6003d797d88cd17.jpg)
