Hi guys,
Just like the add says- I need some help deciding on the 52i insert or the PF100 furnace. Our home is 3400 sqft rambler on an unfinished basement and currently 100% propane. I refuse to go through another winter spending $4000+ on propane.
My quote on replacing the propane insert fireplace with the 52i was about $6100.
The used PF100 is $2600 and is about 5 years old.
Harman 52i:
We have a very open floor plan but the house is very long. The pellet stove location is our sunroom/living room. This shares an open space with the kitchen and dining area. My concern is that the 52i won't suffice as a primary heat source.
Pros: looks, local heat to our living space, new.
Cons: cost, uneven heat distribution, storing pellets near our living space, may still need propane to supplement.
The local Harman installer did a site visit and didn't think I'd have any issues with even heat, however he also assumed the house was ~2200 sqft after I gave him the tour. Not sure I want to proceed based on his opinion.
Harman PF100:
The pellet furnace would be located in the basement. I don't think we'd have any problems heating the entire house with this unit. However, I've never had a pellet stove, let alone a furnace. So I am slightly reluctant to diving into a used unit. I'm unsure of problems and maintenance they may need or have a history of needing. The only other negative for the furnace is its location... 9 hours from me.
Pros: even heat, plenty of room in basement to store pellets, eliminate propane use, larger hopper.
Cons: being 5 years old, still have a worthless propane fireplace in the living room, driving distance to pickup, unknown history outside of what the owner decides to tell me.
The owner claims he is selling it because he travels quite a bit and can't rely on it for his sole heat source while he is away (runs out of pellets). He plans to buy a regular pellet stove to use while he is home and use an oil furnace while he is away. He is not negotiable on price![Down :( :(](/talk/styles/default/xenforo/smileys/downer.gif)
What would you guys do? Which of the above would you pick, or would you pick a different route? I'm all ears. Any opinions or suggestions are welcome. I'm ready to pull the trigger on something before the cold hits. Sorry for the long post...
Travis
Harman 52i:
Harman PF100:
Travis
