Hi! I was hoping some folks may have some input on some questions I have before installing my woodstove. I am going to be installing The Hobbit woodstove in my tiny house. The woodstove requires 18 inches of clearance to the rear and 16 for the sides. I have built a wooden stove stand for it to stand on. I will most likely use tile for the base to protect the stand. I am hoping to reduce clearances by 50% with a heat shield. I was hoping to use 22 gauge copper sheets for this. My walls are 3/8 inch cedar tongue and groove. Here are some of my questions:
Is copper an adequate material for a heat shield? Dies the spacing need to be greater?
Should I be concerned my walls are cedar tng?
If so, should I attach the copper sheets to cement board? Or cover the wood walls with cement board?
Any advice on this matter would be greatly appreciated! I haven't found too much info on copper heat shields on the web. Thank you in advance![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Westin
![Need heat shield advice. Copper shield for wood walls? Need heat shield advice. Copper shield for wood walls?](https://www.hearth.com/talk/data/attachments/199/199880-bf1a02592bc23146ebb2af6b4e5c570c.jpg)
Westin
