Hello
First I want to say this will void the warranty and I do not recommend it for stoves currently under warranty. Now if you have an older stove you want to Rev up and ALSO with a quick wire change throttle back to stock this mod may be for you!
My issue was a dirty burn even though I cleaned the stove. I put a new stock exhaust blower in and it worked good for a few weeks now it is back to dirty burns!
So I swapped out the 1.0 Amp exhaust blower motor for a 1.5 Amp exhaust blower motor and wow, this stove lights in almost half the time! ! !
Here are the details
1. I took out the stock Fasco Travis large blower and removed the mounting hub.
2. Dissasembled the Fasco upgraded 2 Speed Magnum blower from impeller, housing and mounting hub
3. Drilled out Magnum 2 speed Fasco motor mounting holes to fit the stock Travis large blower mounting hub
4. Spray Dry Moly on new mounting hub and impellers for protection
5. Mounted 2 speed blower to Travis hub and installed Travis large blower impeller.
6. Put new lytherm gasket on stove and mounted 2 speed blower into stove
7. Changed female clips on blower to plug into female clips on stove. (Made a male to male jumper)
8. Fired the stove and let her rip!
The new 2 speed blower is 85 CFM on low and 105 CFM on high with stock impeller.
White is Common
Red is low speed
Black is high speed
So not sure in the new setup what CFM is.
What I am sure of is this.
Power = Amps x Volts
Stock Travis Blower Motor
P= 1.0 x 115 = 115 watts
New Magnum Blower Motor
P= 1.6 x 115 = 184 Watts.
So far it is running great and I had to really lower the damper. Don't need much air now!
More Power ! ! ! See pics below, click to enlarge
White is Common
Red is low speed
Black is high speed
