Hi all.
Firstly i would like to introduce myself...Dave is the name and i am based in a chilly part of Southern Spain. (in winter that is)
I'm so pleased to have stumbled upon this site, as i am in the process of reforming a house and want to install a wood burning stove.
I have no idea where to even start with this install, but want to make sure that i don't end up burning down the house, so some basic advice would be really welcome, and most appreciated
A bit of info about the property
1.House is 3 storeys, with the garage taking up the first (ground floor).
2. The main living area is on the middle floor (lounge is 26ft x 15ft x 10ft high) there is also a bedroom and kitchen (total 700 sq ft floor area).
3. The guest bedrooms and bathroom are on the upper floor (total 500 sq ft floor area
4. There is no chimney in the property.
5. Alternative heating is available in the form of AC/heating units.
6. I have a multi fuel stove available, which is a Firefox 8 and is free standing (I would like to use this, but if it is felt to be unsuitable, would look at purchasing something more suitable). I will be burning only wood.
7. Floors are concrete construction with hardwood finish on top.
8. Stove would sit on the middle floor in the lounge, and flue would pass through the lounge ceiling (concrete) into the top floor accomodation (hopefully to aid with heating), and then out through the roof (concrete construction)
No bends would be required.
My questions are.
1. How close to the exterior wall can i place the stove. ( i would like to place it as close as possible), Wall is a double brick construction with plaster rendering to the interior and exterior. There is a polystrene type insulation in the cavity.
2. On what kind of base would the fire need to stand?, bearing in mind the floor covering is wood (would a sheet of 1" thick marble suffice)
3. What type of flue is recommended? (Here in Spain, they generally use a single skin flue. I'm worried about this
4. A hole will have to be made in the upper floor and the roof to accomodate the flue. What clearance is adviseable around the flue?.
5. How high should the flue stick out from where it exits the roof.
6. Lastly, and most importantly, is what i am planning to do here fundamentally wrong LOL.....
Any help here will be greatly, greatly appreciated.
Best Regards.
Dave.
My questions are.
Best Regards.
Dave.
