I don't have much choice at all for pellets where I am. I've been burning Hammer's. They've produced a lot of ash and after about 12 hours the burn pot is full of pellets that haven't been fully burned (turned to ash), they're like hot glowing ambers, and the glass would be black. I'd also get a build up of a hard black crust in the burn pot (a little), inside the front of the feed tube (had to scrap it daily otherwise it would impede the auger) and on the end of the auger (chipped off good sized chunks daily). They put out a lot of heat. Many times I've had to keep my feed setting on 1 or maybe 2 even when the temp got into the low 20's and 2 or 3 when it got into the teens. They cost me $229 plus tax ($247 after tax) and no delivery.
I've got a chance this spring or early summer to purchase as much of a local pellet (120 miles from here) as I want. Going on last year's summer price I could get them for about $175 per ton after tax and shipping if I bought 10 tons. I've got someone that wants 2 tons and I can find room to store the other 8 tons which should last me probably 5 years.
I drove up there last week and bought 1 ton to try first. They don't put off nearly as much heat as the Hammers but that might be a good thing given that I'd be able to adjust the heat down when I don't need as much heat. The Hammers would get too hot sometimes. After burning just 2 bags of the new pellets it seems like it takes a setting of 3 to approximate a setting of 1 for the hammers. The new pellets also produce a lot of flying ash, looks like fire flies dancing around in there. They leave much less ash in the pot and don't turn the glass black although they do turn the baffle plate black.
The new pellets are softwood. They are smaller in length and don't seem to need much pressure to break them. There is very little if any dust in the bags. One thing the people at the mill said when I was talking to them was that they have been using a larger screen lately, I forget why. Isn't it better to use smaller size material (dust) then to use larger flakes of wood to make pellets? What they're using is still small but definitely larger then saw dust. What would make the pellets give off a flake or two when I break them? Is it because they aren't dense enough?
They have 2 different colored pellets. The darker ones are cheaper (only slightly darker then the hammers) and a light colored pellet (almost blond in color). The lighter ones are sold for $30 more per ton. Both are sold for horse bedding. Some people like the lighter color for their horses. The darker ones were tested in 2009 for use as fuel and the numbers look acceptable from what I can tell but I think they started using the larger material since then. I think it's the same raw material just not ground down as much.
Density 46.8
Diameter .2526
fines 1.3%
durability 99.7%
moisture 5.16%
ash .48%
BTU 8223
My stove is a Summers Heat 55-SHP22
My concern is the flying ash building up in the heat exchanger, blower and vent. Is it a valid concern? I like the lower ash content in the pot, cleaner glass, and having to turn up the heat setting a little because I now have room to turn it down when the room gets too hot without having to shut the stove off. I can turn down a setting of 3 but can't go lower then a 1 which is where I usually kept the hammers. I also like the much lower price of the pellets even if I have to burn at a little higher rate. I figure even if I use more pellets it still doesn't come close to the difference in price. I vacuum ash and scrap the crust everyday. I recently bought a leaf blower and will suck out the vent at least monthly which should be at about a half a ton or so of burning. Would that be enough to keep the heat exchanger relatively clean?
I'm new to this so please correct my terminology.
Density 46.8
Diameter .2526
fines 1.3%
durability 99.7%
moisture 5.16%
ash .48%
BTU 8223
